My idiot brother hydroplaned my sister's '01 Ford Sport Trak into a water-filled ditch Thursday night. I took a look at it today & couldn't detect water in the cylinders but the intake plenum was very wet so I used the shop vac on that. Tried to turn it over (with the starter) to see if water would shoot out of the cylinders but it doesn't move, sounds like a dead battery or bad starter. Checked the battery & it's good, no reason to suspect the starter. Does it sound like it's hydrolocked? Never had this issue before so any input would be welcomed.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin
www.wwnboa.org if you're interested in '62-'74 B-Bodies
