Hey guys Im curious; after some bench racing with a buddy, Im curious on the cam/specs you run on Hemi solid rollers for reliable street use?
Mine is a 572 with 11:1 oiling thru the deck with Indy heads and Stage V rollers - our premium pump gas is good here. Just wondering what you've all used specs wise ie: lobes/springs etc are for a lower maintenance street solid roller ?
