to a point yes,you are correct,but the smaller the base circle,the more viscious lift and control at rpm becomes,ramp design,you can increase the base circle some,but not a huge amount for sure.once again theres a point of no return..its give and take for sure.......
SFI 25.5 depends,no leak,even at 213 mph....
