low miles 69 Dart and 71 Demon built at LA plant have black power steering boxes.
The paint was not great on these boxes. And they get covered in oil from leaky power steering components. Same reason drivers side lower control arm bushings go out more than passenger side: power steering fluid leaks on them and eats the rubber up.
If you pressure wash or use agressive cleaners, you'll knock the paint right off.
