I have the distributor you need, and am looking for a correct dual point for my 69 GTX. Question: Can a 69 Roadrunner auto distributor (2875731) be built into a 69 GTX 4 spd distributor (2875772)? Ie., are the bodies the same & can the internals be changed from single to dual point?
The 69 440/4bbl 4spd dual point dist is completely different from single points, this is what you are looking for, hard to find, especially with real tags and in good shape
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
