Just for your information: If you get rid of the rag joint, much vibration transfers through the column to the steering wheel. Much vibration tends to make your hands go numb, not something you really want when it comes to steering. Though the rag joint looks to be a weak point, unless the rubber is shot (which is a cheap, easy replacement item), they are very tough. Most people assume the rag joint is to take up steering misalignment, which is not true, its purpose to strictly to eliminate the transfer of vibration through the column. Unless you have driven a truck without a rag joint, you really have no idea how much vibration is present. Don't eliminate the rag joint. Gene
