Just went through this. Make sure you have a good ground to the instrument frame, dash frame, and voltage regulator,and clean the pins in the plug for the voltage regulator. Hope this helps.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
