Im trying to get leaves and crap removed from the suitcase on my 1st gen Dakota.
Its gotten to the point now that the drain is no longer draining, and when I went to the carwash, the water was now draining onto the passenger floor.
Is there anyway to get in there without removing the entire assemble from under the dash?
Or would it be possible to do the old cut a hole trick as seen on the full size AC trucks?
