Hello all, I have been looking around for a 360 to build when I was offered this short block by an aquintence from the mopar world.
I thought that I'd run the specs by you for some feed back.
My first thoughts are that it's a bit too much for a fun street car I am planning.
360 block bored 0.040 = 4.040 = 367 cid
block tubed for roller cam
oil passages drilled
6.123 new connecting rods (6 pac)
new 3/8 connecting ARP rod bolts
TRW pistons 0.160 dome = 12.5 compression with 64cc heads
double roller chain and gear
Crane cams roller 232-242 dur at .050 lift 296-306 adv dur
0.500 lift with 1.5 rockers
roller lifters
all TRW bearings crank .010 rods and mains
bronze oil pump drive and bushings
melodeon oil pump.
I have just copied the info word for word from seller.
Any thoughts on this with a set of Edelbrock heads?
Thanks.
