I can tell you that in the absence of power no it won't park. But it should stop running if you turn the switch off, the blades would just sit wherever you stopped.
The park function is inside on the cover plate for the gear housing. A contact point on the cover plate inside, you should see a straight arm (not bent), the points could be cleaned too.
Need Jules in on this question.
Butch
