My 8 inch glasstek
Is your scoop sealed... where is the seal at in relation
to the hood itself... also where are the carbs in the
scoop... how far from the top of the carbs to the scoop
Carbs are pretty much center of scoop and the front carb is about 3 inches from scoop, rear carb a little more clearance. There is about an inch and half clearance to windshield and carbs are not sealed to hood.
So does it run quicker sealed to the hood or not sealed?
I had a smaller cowl hood with a single carb and sealed it to hood and didn't make a bit of difference, now with the tunnel ram and two 4's i didn't mess with trying to seal the carbs on this hood.
Do you have a SB or BB?
BB
