Goldman out of Allentown Pa. does my transmissions and told me that ATF+4 is the best for 727's and 904's.
You can run it all year long and your transmission fluid will look like new.Clutches and steels look mint too.
build the unit correctly and you can use any fluid all year and it will look like new.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
