Make sure you replace both filters and only use the Mopar screw on filter.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
