First off the came was installed at 110, and I had to use the different key way on the crank sprocket because I couldnt get enough adjustment out of the offset keys on the cam.
I intially set the lash to 028/032 for the break in and the first 200 miles, then I tightened them down to 017
*69 swinger 340 4spd *70 T/A 340+6pk 4spd
