I would echo Ray's comments on the MT Drag Radial, we have used them for the past three years (one set, 295-65's, @5000 miles on them now), rain and shine, with no problems (and we've been through some pretty heavy rain a few times). I do use a little common sense and don't go fast around curves in the rain (disclaimer: your results with bigger tires and lighter cars may vary!). In 2009-2010 we used BFG Drag Radials, also with no problems in the rain (but they do not work as well on my car at the strip as the MT's). At the slower times we run in DD class it's just not worth it to do all that work!
I used to carry a spare pair of rockers when I was using Crane aluminum units, but switched over to stainless rockers and now don't carry any valvetrain spares (I've got flat tappets and thick pushrods). I figure if something like that goes really bad and puts a bunch of metal in the engine I am more inclined to call it quits rather than try to press on and cause more damage ($$$$$$).
What I carry in the trunk: Toolboxes for mechanical and electrical repairs. A spare, unmounted MT rear tire (I use the space inside for additional storage - no trailer!)and a small space saver spare (from like a late 70's Cordoba) in case we get a flat on the road. The spares are electrical and fuel parts that are not readily available at an auto supply, or something that will stop us on the road: spare MSD 6 and pickup, spare coil, plugs, cap, rotor, spare Mallory fuel pump, fuel filter elements, and carb tuning kits with extra gaskets. We use an engine driven fan and water pump so we just carry a spare belt. A few extra lug nuts, plus the lug nuts and wrench for the spare ride with the jack. Enough oil for a full change and a filter, a one gallon water jug (full), a fuel jug (usually empty), some rags and paper towel, gloves, glass cleaner, oil change pan, brake cleaner, funnels, brake fluid, 2Q ATF, a 6' -8 hose with a fitting rigged up so I can connect under the hood and pump fuel out into a jug in case somebody runs out of gas, big flashlight, a thick old rug to put on the ground and folding chairs so I can relax and wait while Doc Fox works on his 'vette on the side of the road.
Cooler, bottled water, suitcase, fire extinguisher, another flashlight, and helmet go in the back seat.
Scott
