The unit is mounted under the battery. Several reports of battery acid problems with wiring. Check the vacuum connections. I've had a squirrel chew through the harness more than once. Must be pretty tasty?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
