Quote: I would just run the Schumacher mounts and cut a hole in the hood for a scoop.
Other than obvious sarcasm and him not installing the Hemi with factory style parts, why would he have to cut a hole in the hood?
Mine clears the hood just fine (but it is a 67). The hood pad just barely touches the top of the chrome dome air cleaner with the hood closed. If I took the hood pad off it wouldn't even do that.
