Does anybody know what size hole needs to be drilled into an intake to use a water pump bypass hose? Also, what size threads to tap for the nipple that would go into it? I picked up an Indy 360-3 intake and this area is currently closed off, and I would like to run the bypass hose since this is a street car.
Entire Thread
Subject
Posted By
Posted
Drilling and tapping Indy SB intake for bypass hose
