Cut the rivets off from the backside and push them through. Do not drill them, it will cause them to stin and damage/scar the plate. I blasted mine lightly and it came out great, I only blasted the front side the back was excellent.
I think cutting off rivets from a dash that you are restoring is opening the door for
All it takes is a little extra time and effort to carefully mask the tag for stripping or painting.
