What's the rated compression ratio ?
Edit ... mymopar.com says rated at 8.8 so it's closer to 8.0 , you should be able to run it on 87 ...
Maybe carboned up cause of the 91 it couldn't burn?
A carboned up engine can run bad. I bet a dose of Seafoam in the PCV would put on a real show.
I want my fair share
