Pictured here is our custom bell-housing engine adapter to adapt the 6.1 Hemi engine to accept the prowler style drive shaft an rear trans. The rear engine mount is also integrated into the bell-housing.
[/IMG]
Modified pan
[IMG][http://i139.photobucket.com/albums/q290/treyb1/Trey%20B%20SRT8%2061%20prowler%20project/prowler%20hemi%20in%20progress/552bf81e.jpg[/IMG]
Handbuilt headers and exhaust
Custom shaker hood from a Challenger
The first step was a custom trim ring.
On the picture below you will see a aluminum ring around the shaker. This set the positioning and build up area that the shaker with come through from the engine.
Then using tape the team laid out the build up outline design form the custom aluminum piece to be built, formed and attached to the hood. As you can see its slopes only leaving the top of the shaker sticking through. Very creative. See side view
[IMGhttp://i139.photobucket.com/albums/q290/treyb1/Trey%20B%20SRT8%2061%20prowler%20project/04299455.jpg[/IMG]
Hand built to match the shaker
