Hi guys I just bought a reproduction reverse light switch wiring harness. I have one end that goes onto the switch on the trans,I already plugged that in. The other end has two flat connectors that need to go in to a plastic plug or directly into the engine,headlight,wiper motor harness thanks James
the pictures i up loaded one has a little harness in the picture the other is what i have
