The Griner is a low band apply(LBA) valve body. My only experience is with the TA non low band apply vb. I never downshift when i slow down. I've heard that a LBA vb will jerk when shifted into first while moving. Again, no experience with the LBA type. Obviously if you slow down and then need to accelerate from a low speed, you may want to downshift. I will sometimes take off in second when driving in ice and snow. Otherwise it's not a good idea, due to converter slippage and heat.
yes..down shifting into 1st with a LBA valve body will cause the engine rpm to go up...and transmission will be braking or slowing the car...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
