hey guys it went a 1.084 60 ft 3.134 330 ft 4.801 660 ft 148.33 mph at the 660 and 6.23 to the 1000ft clicking the motor off at 5.941 into the run.im running q16 so I wanted to get the jetting right.i have not made a all out pass yet.it went 4.75 at Norwalk.after looking at the racepak I was slipping the clutch.i also need to change the gearing in the lenco it pulls the motor down 2000 rpm on the gear changes.i cant see the shift light when I pull it its at 8200.the car weighs 2550 with me in it ,im going to try and get some weight out. we will see what happens next season.thanks Pail for the awesome videos you are the man.
