I would run the Performer but keep the SD unless you REEEEEEALLY need the money. If you need every penny then sell the SD. Keep in mind if you ever do your 440 up for the performance it is legendary for the Performer intake will be a restriction. AND if the SD is no longer available new you may want to hold onto yours. The SD is a high perf intake that does not sit as high as the Performer RPM.
Keep old mopars alive.
