OK, let's try this... are 4 door bench tracks the same as 2 door bench tracks??
Yes, they are the same.
PARTS VENDORS WILL TELL YOU THESE ARE THE SAME
Sorry Laysons... THEY ARE NOT!!!
I have personally owned both a 70 Coronet 2 door
and a 70 coronet 4 door...
The tracks look very,very similar as do the bench portions of the seats...
but they are NOT THE SAME...
For the record, I am looking at a factory parts book for 70-71...
The part numbers listed in the parts book for the 70 Coronet with a split bench seat are
DIFFERENT than the 70 4 door versions...
Now given that..
You should ask 3 questions..
1) Will 4 door seat tracks pulled from a 70
Coronet 4 door physically fit in the
70 Coronet 2 door car in the floor pan..
WITHOUT ANY MODIFICATIONS? (i.e drilling)
The answer is: YES
2) Will the 4 door tracks attach to the 2 door
bench seat in the exact same positions?
I don't know this.. you'd have to try it...
3) Will the 70 Coronet 2 door split bench seat
with 70 coronet4 door seat tracks attached to
them lay the same once in a 2 door car?
(i.e seating angle)
Not exactly!
The 4 door bench is physically a different seat than the 2 door split bench seat. Again they look very similar...
I have had both off of their tracks laying on
a garage floor..they lay differently!
The 2 door bench seat cover will not fit a 4 door bench seat or vice-versa...
The ultimate question is can you get them
installed and get them to work
Most likely YES...
Can you live with the differences: Probably..
But they are different....
