Both valvcovers showing milky moisture near breathers and coolant level is dropping. We have removed both heads and had them resurfaced and thoroughly checked again. Replaced head gaskets again using felpros and the same problem is there. This engine has very very few miles and the problem has been there from the beginning. The coolant is not on the floor or in the oil pan could this be a broken block?
