i always look at the dowel pin holes. small block is straight across from each other. big block the starter side dowel pin hole is higher than the other side.
Ya beat me to it. Also you can measure the distance between dowels openings on the case and measure the dowels in the block.
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
