I wouldn't advise cranking the motor over. You will wipe off the cam lube. I like the idea of turning the motor upside down and coating the bottom side of the motor. Then fog the cylinders and ports. Bag it up and get some dessicate as mentioned it should last a long time....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
