You might even have one for a /6. The ones for a V-8 had more of a longer drop or 'dip" in the "S." It's to clear the oil pan without rubbing. Some people forget to change when they convert to a V-8, then run into some problems. They might have mis-boxed your part.
A True Hybrid: Burns Gas AND Rubber!
