I had the best luck spraying it in thin coats with several hours of dry time between each, use 80 psi and hold the Shutz gun at a very sharp angle to the surface, almost parallel, to push the material across the surface rather than straight at it, this will help put some slopping feathered edges to the tips of the waves to give it that wind blown wave or cake frosting look.
