Re: distributer indexing how to do it?
#15044
03/30/05 03:18 PM
03/30/05 03:18 PM
Posts: 961 Carson City, Nevada
RobbMc
Carson City, Nevada
here's the question: if my distributor needs indexing or re phaseing how do you move or adjust the roter? it's a mp performance dist. is there a way to rotate the shaft under the rotor with out moving the shaft with the reluctor pressed onto it. is it a 2 piece shaft or something? i am going to cut a slot in my cap and shine the light in to check it. if it seems like it's off i just wanted to know how to reline it up closer. thanks.
KNOLEDGE IS POWER I need to learn how to spell first huh?
There is nothing in the design that is intended to allow the end user to phase the rotor to the cap segments. However, there are several ways it can be done. First, however, determine if it is really necessary.
Cut an old cap so that you can see the rotor to cap segment phasing and the reluctor to pickup relationship. Line one of the reluctor points up with the pickup and see where the rotor is pointing. Ideal phasing depends on several factors. If you do not use vacuum advance and you do not use multiple spark ignition, the best phasing is to have the rotor point directly at the cap segment when the reluctor point is lined up with the pickup. If you use vacuum advance, the rotor blade should be a little (about half the blade width) late so that when the vacuum advance is engaged it pulls the blade back to the center of the segment. If you use multispark ignition, it is better to have the blade a little early (about half the blade width) so that the blade is still lined up with the segment during all the sparks. But if you use both vacuum and multispark the two cancel each other and you want the blade pointing directly at the segment again. Other factors may also influence the ideal phasing (such as intended use of the engine) but these are good starting points.
If you need to change the phasing you have three choices: purchase a special reluctor with extra roll pin grooves machined in the I.D., machine extra grooves yourself, or, if you're careful, you can slightly bend the arm on the pickup so that it lines up with the reluctor points either later or earlier. If you bend the pickup, make sure you reset the gap afterward.
