You can put a 518 in there!
Fairly simple instal with minor fabrication, or donor parts.
Plus side is you get the overdrive, and lockup features (if you use a lockup 518).
Down side is you have to do some driveshaft mods.
But that overdrive really helps if you do much driving over 45mph.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
