Bought it online to do a dash overlay for it. I had been making some Lil Red Truck door overlays and was going to add the long woodgrain trim piece(s) that go along the bottom of the dash and then decided to do the dash also.
The seller didn't know what it was to. I knew it was a Dodge truck but hadn't been able to find the year/model it was for. I did see one other like it but it had DODGE in the metal plate below the rectangular (radio?) opening.
I did a woodgrain and a carbon fiber overlay. Was also gonna do them on a new, thin brushed alum look plastic backing so they are easy to install and replace a damaged or corroded metal plate on an old dash. Been doing that for the early A body rally dashes.
Heres a picture of a 73 I found online. To the left, where the picture is cut off, the plastic dash housing I have has a hole for what I'm guessing was a clock or tach. the metal plate on the dash I have doesn't have the whole and is woodgrain. I'm assuming the dash came with or without whatever that was.
In the picture you can also see the DODGE lettering. The dash I have doesn't have that.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
