Re: Help, My AM thumbwheel radio won't tune
[Re: rarefish]
#1496134
09/05/13 07:11 PM
09/05/13 07:11 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
However, your problem is going to be a broken plastic gear found behind the tuner thumbwheel. They ALL break. Greg
Listen to this , this is 99.99999999999999999999999999999999999% the problem, if you can turn the thumbwheel and do not see the plastic gear turn with the thumbwheel no amount of adjusting/cleaning of the clutch is going to fix it.
Well, that is my problem. The plastic gear that is located in the middle of the thumbwheel is not turning when I rotate the thumbwheel. What locks the plastic gear to the thumbwheel? Is it non repairable once it starts to slip there?
The press fit of the 2 parts, the gear is BROKEN ... Repair involves replacing the thumbwheel , contact Greg ward .
Entire Thread
rarefish
09/04/13 04:12 PM
hemi68charger
09/04/13 04:37 PM
WINGCARS_6970
09/04/13 04:58 PM
Jim_Lusk
09/04/13 06:12 PM
rarefish
09/04/13 06:39 PM
Jim_Lusk
09/04/13 07:29 PM
rarefish
09/05/13 03:09 PM
Jim_Lusk
09/05/13 03:39 PM
BigMoneyLewis
09/05/13 03:46 PM
JohnRR
09/05/13 04:24 PM
rarefish
09/05/13 09:38 PM
JohnRR
09/05/13 11:11 PM
JohnRR
09/04/13 08:36 PM
hemi68charger
09/04/13 09:39 PM
Cab_Burge
09/04/13 10:21 PM
BigMoneyLewis
09/05/13 01:50 AM
