I am still running the same Carter "strip" electric pump I installed back around 1984. It has never failed me. PERIOD.
It hangs proudly in the breeze under the car, it operates after sitting for more than a year full of fuel, Mmy only wish is that the hot rod shop in Cheyenne, WY would have had a "street" pump in stock the day we rolled in off the Interstate and bought this one, installed it in the parking lot. Because it's a strip pump I have had to use a regulator.
I've bought others of this configuration, used, for pennies and never had one fail. They even make a 6 volt model for your old iron!
If you can get a tank mounted pump it'll be better, or if you have an extra $800 you can buy the Aeromotive kit that is really slick. But if you need to get fuel to the front of the car that Carter'll work.
R.
