This is my first moparts restore I put a new complete floor in my challenger from front to back I want to convert the auto to stick. I'm guessing I will need the tunnel hump to weld in but what about the console can you make the automatic work with the 4spd and dies anyone sell a short throw shifter design thanks all
The console's are the same, except i believe there is a cutout on the side to clear the rubber boot. You will need a difference top plate as the cutouts are different for that as well.
The tabs that mount to the transmission and the shifter linkages on my transmission have 2 different mounting spots. I guess the ones closer to the shifter forks are "shorter"
