I'd like to know more about this.
The "offset" is built into the brake supports, right? Why couldn't an 8 1/4" brake setup work? They physically fit the 8 3/4 housing. Is it a matter of the amount of axle shaft and hub that sticks out of the housing? I have mixed and matched parts here many times and it worked out fine. Maybe I got lucky?
