Yes I am. This is my first big block build. 74 block stock bore, 452 heads tempate ported and cut .100 to make the closed chambered.M-1 intake w/ BG 850 carb. Comp 284 cam wirh roller 1.6 rockers, schumaker headers,2-1/2 all the way back, 727 unknown high stall. 355 grip lock mini tubbed and ss springs. I need to hook my wide band up and get some meat under it...
Its coming together... I did have fuel problems and finally got that straighten out....boooo waaaaaaaa!
