Does the return at the tank need to be above fuel level? I've noticed that low pressure race setups are above and factory high pressure setups are below. Will a low pressure high flow race pump for non fuel injection work with a return in the middle of the tank?
With no scientific evidence , I am going to say yes.
Plumb it into the filler neck or top of the tank for the same reason as using a larger line. You don't want the back pressure that forcing returned fuel to the tank through 1/2 a tank of fuel would provide.
If you're using a cell , there will be a fitting located where ? Yes....on the top.
I put mine on the top front on the pass side because that is the side the return runs down. An oval track deal would want a little more thought than that.
I had searched for an answer to that and found nothing on it.
I have a car with a stock tank and plumbed the return at the sending unit. 3/8 fuel line with 1/2 return. It was working fine until I filled the tank up. The pump started surging after the fill up.
It's a Mallory 140 pump. Looks like I'll be moving the return.
NMCA NSS 67 Coronet
