Just for the heck of it....for a similar project...what all would entail the modification of a 69 Charger to accept the engine/trans of a 2011 Charger? Where do all the wires run? Can they be run to stock gauges? Will aftermarket have to be installed? How will Linkages be run? How about all the sensors, what do you do with the main ECU?
I am pondering something...see if I have the brawn to face a modification of this magnitude
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
