Sorta: Not a powerhouse in stock form but a cam grind, headers and intake swap will wake it up. A 360 magnum is a lot more powerful if you can find one with usable heads. I think the 88 is a 3 speed non overdrive as well. Any 360 Magnum automatic will be an overdrive 4 speed automatic.
Sheldon
