I made an error when I originally posted that sequence. I had the dished plates/discs flipped around backward.
2 types of clutch packs are available. The "smooth" version includes dished plates, the "aggressive" version includes dished plates and dished discs.
Starting at the clutch hub:
1. Flat plate with ears
2. Flat disc
3. Dished plate with ears (ID facing away from clutch hub)
4. Flat disc or dished disc (ID facing away from clutch hub)
5. Thin flat plate with ears (OEM only) Repro power-locks use thick flat plate with ears
Prelube clutch pack with straight friction modifier. Torque case-half bolts to 50 lbs with red loc-tite.
