Quote: Here is the all new Proformance transmissions TH400 2-Speed tranny for the Challenger. It utilizes the all new Reid TH400 case and bellhousing. It has a lot of trick features as well.
Looks expensive, hope to see the numbers soon. Are you using the same turbo as the bruders?
Brett Miller W9 cnc'd heads STR Chassis fabraction
