If you know anyone in the Indy area that works on Mopar electric problems please let me know that as well. Thank you !!!
Sounds more like it's an MSD electric problem.
Sounds more like it's heat induced. Get a couple cans of freeze spray and when things start acting up hit it with some freeze spray and see if it stops, if so that should narrow the problem down. I'd also double check all connections for tightness.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
