Ok going to check out some simple stuff this week, kickdown linkage, maybe adjust the bands... I changed the filter/gasket last fall, and it was a little low on fluid, but I topped it up and made no difference.
Trans was built by a reputable mopar transmission guy I have known for years, probably around 96. I bought the MP kit, and a 5:1 kd lever.
Problem is this, 1-2 shifts aok, hard like it should be if on the throttle, but 2-3 it will not unless I let off the throttle some, then it is soft. Also when I hit a certain speed (110 on my speedo, but it is wrong...probably 85-90 or so) it slips, like I get nothing.. it does not keep pulling. Never had this before.
74 Roadrunner 400 console shift. Recently had the carb off, this is why I think kickdown adjustment.
