I'm replacing the upholstery on my seats (73-74 A-body buckets) and I've run into a small problem. The seat foam is in great shape, but the frame needs some welding repair. As the foam wraps right around the frame, I am having trouble telling how to remove the foam (it seems continuous, like it was molded onto the frame) so that I can re-use it. Any tips?
Thanks!
2 Demons...no, not my kids!
