there are 2 nipples up high on the tank that connect to vent lines , one line goes into and out of the trunk floor above the rear axle the other looks like the number 7 and clips to the shock crossmember , the line on the frame rail front to back connect to the fuel sending unit.
The one that you say looks like the number 7 is missing... any pictures??? The other one is already hooked to the hard line that runs through the trunk.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
