Thank you everyone for your replies!! It seems to me like it's scraping the fender lips most, rather than the wheel well, because I see grooves sliced into the tires from the fender's edge. The scraping happens more often on the passenger side (whether I have a passenger or not) and happens either when I turn (especially to the left) or when I bottom out on a bump.
Classic sign of incorrect backspace. These tires will fit fine with 4.25 to 4.5" backspace on the wheels. Odds are your wheels lack this amount. It could be these are even Perrles Tyre generic wheels with Eagle caps or any number of combinations. I think the standard spacing on a lot of these types of wheels is 3.5 to 4, depending on the width.
