Same problem on my 340. I installed a Cloyes double True Roller chain and fought to get it on with the tensioner.
I had to have my brother hold the cam in place so it wouldn't bang against that rear plug. Then, I used my fingers to push against the chain and tensioner at the same time.
Once I got the first row on the tensioner I was able to slowly work the chain and gears into position.
It was tough.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
